Page 11 of 27 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 270
  1. #101
    Sep 2010
    Collegedale, TN
    You'll be fine. No need to fill the block.
    1986 Saltare
  2. #102
    Nov 2011
    Paris, France
    Thank you Titan, I try it next week and will probably do a video of the engine running.
    Cheers
    1989 Supra Saltare
  3. #103
    NW Houston
    The boat looks great - all your efforts have really paid off. That interior looks factory fresh. You are sure to inspire the addition of more Supra's to your area once they see that beauty on the water.
    Like Titan said, you'll be fine without filling the block. With no water in the block, the thermostat should heat up and open in only a few minutes to fill the engine once it's running. Just watch your temperature guage - I think the stock thermostat is a 145 deg F, so the temperature will probably rise to 150-160 deg F & then drop down once the thermostat opens.
  4. #104
    Jul 2011
    St. Paul, MN
    Stephane,
    Hey its matt, you had found me on YouTube last year. Boat looks awesome and i will take some credit for persuading you to buy it! Just found you on here so thought to say hi. How close to wakeboarding season are you?
  5. #105
    Nov 2011
    Paris, France
    Hi Matt, glad to see you here as well. The boat is actually at a place for a new cover. I take it back next monday. Then, I need to change engine and transmission oil, filters, polish hull, and put it in water. Maybe half of next week. Then it's begining of wakeboarding this beast.
    I will take photos and videos of our tricks.
    Stay tuned
    1989 Supra Saltare
  6. #106
    Nov 2011
    Paris, France
    You were right guys, today I start the engine. No problem of temperature, when the thermostat opens, water enters engine. It runs just perfect at idle, but impossible to rise RPM !!! I tried with Choke and disconnected choke, nothing to do.
    But I'm afraid to open the carburetor. The risk is to never start again ... I try to find litterature on it.
    Also, idle is arround 600rpm, the alternator does not charge the battery. But I remember on the friend's X35, no charge at idle, it needed to be arround 1000rpm to start charging. So, I will wait that the engine runs perfectly before deciding to change the alternator.
    1989 Supra Saltare
  7. #107
    Sep 2010
    Collegedale, TN
    Idle should be around 850-900. Go ahead and get a carb rebuild kit. It's easier than it looks and you'll eliminate a lot of possibilities by rebuilding it now.
    1986 Saltare
  8. #108
    Nov 2011
    Paris, France
    Yes I start to look if I can get a rebuild kit directly in France (because of delay and cost of shipping). But I'm more afraid about retune it after changing parts. As I will clean and remove every srew, I think a retune will be necessary. That procedure if for me the big problem.
    I keep you in touch. As it's raining and it will all the week, I can't start it again till next week. I would like to make a movie and share it before doing mistakes.
    1989 Supra Saltare
  9. #109
    Oct 2011
    Jonesboro IN
    Holly carbs are probably the easyest ones on the planet to rebuild.
    If it idleing ok but will not go past that you excelerator pump is probly bad.
    Its under the front fuel bowl straight down from where the fuel line goes in.
  10. #110
    Nov 2011
    Paris, France
    Hey guys,
    On the carb (on the choke plate's body) I can read this reference : "LIST-80262".
    I find this : http://www.jegs.com/i/Holley/510/703-28/10002/-1
    Is it what I need ?
    1989 Supra Saltare
