Originally Posted by
sybrmike
Don't forget the other area for adjustment is where the clamp block attaches to the steering tube on the rudder end of the cable. Turn your wheel lock-to-lock to find the center of travel, then rotate the shortest direction to get the shaft keyway where you need it and lock it down in that position. Then loosen the clamp block & allow the steering tube to move fore & aft as you manually center the rudder. That'll get you a straight wheel and straight rudder, but you may end up with too much differential travel in either direction depending on how far you have to rotate the hub to center the keyway.
