Results 1 to 2 of 2
    Feb 2011
    Raleigh, NC
    Default Does the 09 21V sound any alarm with high temps/etc?
    It is no where to be mentioned in the manual I have (that I have seen) if the instrument panel alerts you with anything if temperatures/oil pressure/etc drop to dangerous levels.
    Does it?
    Aug 2009
    London, Ontario, Canada
    i know that your screeen will start to warn you if you get over about 185 and definitely above 200. I found some good repair manuals via a moomba forum guy and I posted them in the how to section. Or you can go to bakes on line they have a wealth of stuff there
    2009 21v Worlds 340 Cat
    Doug
