Originally Posted by
ngavdba
I started with 216 before the first coat after I had sanded and cleaned the teak initially. They recommended 3 coats, sand if you want to, then add a fourth coat.
After 2 coats my teak felt a little gritty so I sanded between the 2nd and 3rd coat cleaning with 216 of course prior to any coat.
After the 3rd coat, I gave it a quick light sand once more for the hell of it. I didn't go at it as hard with the nylon as I did after the 2nd coat.
Cleaned again with 216 and then 4th and final coat.
I could only get to work on mine on the weekends since it took well over 3 hours per coat with the amount of teak I have. Once you get started, the Cetol sets up pretty quickly so have everything laid out and ready to go. You must wait at least 24 hours in between coats, but some of my pieces were still tacky I felt after 24 hours. Anyway,
I had a week between coats and that was more than enough. Keep a wet end on the teak and just go with the grain. Cetol is a very easy product to use and it only ran in a couple of spots where the screw holes are. I sanded it out and did a spot touch up.
Falling in love with my teak all over again and I hope it holds up well to the elements.
