Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Apr 2012
    Acworth, GA
    Default how good is this deal? 1984 sunsport 1061 hrs. 5k?
    owner claimes to have had it since 1986, and that the gunnels were replaced by Supra on a recall in the early 90's. boats interior is in decent condition and the teak is there but has not had any oil or any tlc in a long time. The hull has some discoloration from sitting in the slip at his lake house but might come off with some cleaner and a little wet sanding. Owner said there is a minor leak from the main shaft where it exits the hull but 'it swells shut when in the water", not sure I'm buying that story and assume it needs to be replaced. Floors seem solid and so do the seats.
    Thoughts? What should I be looking out for on a 26 year old Supra with over 1000 hours on it?
    Apr 2012
    Acworth, GA
    here is a picture I snapped. Going back to see it again out of the garage latter this week. There was to much stuff to move to take it out while I was there yesterday. photo.jpg
    Apr 2012
    Acworth, GA
    Quote Originally Posted by paverman View Post
    I was hoping for some feedback, What does one of these normally go for? I am a newby to the world of comp boats....
    Mar 2010
    Windsor, Ontario
    The Supra boats are great and the design for this era was very advanced. The only bad thing was the stringer rot and how the floation foam would aid in the rotting of the boat from the inside out. Typicially the issue lied in the super trap exhaust sytem on the rear transom of the boat. Water would wick into the foam making it waterloged and rot the stringers and floor.
    So the millon dollar question is... How are the stringers in this boat??? Chances from looking at the water marks on the bottom side. I would think weak if not completly rotten. The boat might of had them replaced in the past but more than likely not. As for price it is not bad for a solid stringer boat but if the floor or stringers seem tough or another tell tale sign is brown oosing from cracks in the stringers I would say away. Anything can be fixed but it will cost about 3500-6000 depending on the overall condition.
    Keep in mind sometimes it is better to buy something for a little more today so you have to spend less tomorrow.
    May 2011
    McDonough Ga
    I have a 1984. It's a "Rider" not a "Sunsport" that year. Sounds like $5k is the top of the price range for that boat. I wouldn't pay over $4k for that boat the way you described. You need to check the the lag bolts at the engine mount to see it they tighten up or just spin. The wood stringers in these boat rot over time and have to be replaced ($3K job). Search this sight for info on that. There' s tons of it.
    Its a fun open bow boat.
    Most of the things I replaced on my boat were electrical so far. New blower, bildge pump, fuse block, add a second battery, new radio, new switches, lights, and some wiring. All of witch had corroded over the years.
    Take it out on the water before you buy it!
    $3000 - $4000 is a fair price for that boat in the condition you described
    Apr 2012
    Acworth, GA
    Thanks for the advice, I will be putting these pointers to practice this week when I take a closer look at the overall condition of the stringers and floors. I am assuming that there might be some tell signs around the exhaust ports also? I will be putting some tourque on the engine mount bolts and requesting to do a core test of the rear of the stringers.
    Thanks for the advice.
    Oct 2006
    Marietta, GA
    Take a screwdriver with you and start poking. Agree with Edge on model as bow rails pretty much give it away. I wouldn't pay more than 3k for it. Is it in GA?
    Apr 2012
    Acworth, GA
    yes, its in North GA. I've been reading on the board about the stringers and the leaks from the exhaust ports, he never mentioned having the ports resealed so i am betting that they are leaking.
    Apr 2012
    Acworth, GA
    one other thought/question... when I gave it the quick once over yesterday I noticed that the stringers looked like they are fiberglass and not wood, I am assuming that they are wood covered in fiberglass and that there is no way that the boat has fiberglass stringers installed by supra during a factory recall? And to that point, did Supra ever recall the '84 and rebuilt the stringers under a warranty claim??? That part of the owners story kinda strikes me funny. sound like with all the stringer issues on the board that Supra would go broke if they recalled the boats for stringer rot...
    Oct 2006
    Marietta, GA
    How far north if you don't mind me asking?
    Your assumption is correct. Wood over fiberglass. No recall that I ever heard about.
    Let's see...with mine the floor had partial stringer repair and new floor after 12 years. Muffler Trapps rusted off few years later which leaked. Swim deck supports rotten after 18 years which leaked. Compete stringer repair after 26 years as it was completely rotten through and through. New rudder after 28 years as it leaked. Mine is trailered and never sat in the water constantly. That is Supra for you and can't believe this boat would be any different. Not trying to scare you but prepare you.
