Does anyone know where I can get a wrench that will work for this job? I have an '06 21V. Thanks.
2006 Launch 21 V
Any BIG cressen?? wrench will work. Needs to open up to a 1"-1/2"
89' Comp rebuild thread:
http://supraboats.com/bbs/showthread.php?t=8193
89' Comp Mod's and fun pic's:
http://www.supraboats.com/bbs/album.php?albumid=86
Thanks Jet, but I was having a hard time with the length of the wrench. It seemed to be a very small amount of room. I did not know if there was something that would work better.
2006 Launch 21 V
Just an fyi I ordered this wrench off of ebay. I will let you know how it works out.
1-7/8" Shaft Packing Wrench for Inboards
javascript:;
2006 Launch 21 V
Go to the hardware store and get an adjustable wrench for sink drain nuts. They are wide, thin jawed wrenches with a short handle. They sell the same ones at west marine (for about twice as much).
I use an 'S' shaped adjustable wrench that is probably 100 years old! No kidding, it works great. I like the idea of the sink drain wrench.
If there is damage to the prop has been on a while you will need to pull the prop off. This will make sure you do not damage the prop more.
http://www.westmarine.com/webapp/wcs...splayErrorView
RAM MOUNTS
3 and 4 Blade Prop Removal Kit or Tool
