Results 1 to 6 of 6
    Nov 2011
    Default Wakeplate gauge issue on a 05 21v
    So i bought my new to me boat in November and the gauge was working fine. Used the boat a couple times this year so far and sometimes the gauge works sometimes it doesnt. First time out this year it didnt work so at end of weekend i topped off the resovoir with fluid which seemed to solve the problem until i put the boat in again. Anyone have this issue before or any advice on what to check next?
    Dec 2010
    I have the same problem with my 08 SSV with only 30 hours on the boat the wake plate gauge starting jumping around. The dealer says the gauge is broke and needs to be fixed. Warranty doesnt cover this. I know right boat is like new and a gauge is broke already. I think the gauge is only like $70 from the dealer I plan to just replace it myself. Let me know if you find anything out on how to fix this?
    Nov 2011
    Ok I was thinking about trying to get a new gauge as well since the plate goes up and down with no issues but just was trying to see if there was something else to look at before i did so.
    Mar 2010
    Windsor, Ontario
    What is the typicial fluid in the wake plate?? Mine works but sounds like it is low in fluid. NTM the guage is stuck on zero....
    Mar 2010
    Switzerland
    yeah, my wake plate died last year (2008 21V9) - lost all Oil and &%ç%&.... maybe there was a reason supra changed to electric.
    Apr 2012
    Tacoma, Wa
    Mine takes ATF. I had the same issue with my gauge. I followed the hot wire from the gauge to the fuse block (mine was a pink wire) and cleaned the connection. It fixed the issue for me. With mine I got a little screwed up not realizing that the ignition has to be on for the gauge to work but the actual tab only needs the battery on.
    2003 Supra Launch 22SSV
    1986 Ski Natique 2001
