Results 11 to 20 of 29
  1. #11
    Feb 2012
    Kingston, ON
    Quote Originally Posted by DAFF View Post
    Rather than spending the whole summer fabing the roller trailer why not buy a trailer specifically designed for these boats. In the long run you will be much happier and spend more time on the water. $ for $ I don't see much diference in cost in the long run. Sure they might be harder to find but with all the stringer rotten corpses out there you will find something in the budget.
    agreed... http://www.supraboats.com/bbs/showth...n-western-Mass. buy this and switch trailers and either fix it and sell it or just sell it and get your money back.
    Better yet buy it go home through Ontario, drop the boat off at my place... I'll give you a few hundred for it... and go home with an empty trailer, and sell the one you got. Takes a weekend.
    And no a comp isn't the same as a Sunsport.
  2. #12
    Mar 2012
    Chain of lakes, IL
    Quote Originally Posted by matt k View Post
    a sunsport is just a closed bow comp, right?
    Either way, here's what mine looks like on the factory trailer:
    the angles are different, but your front axle doesn't look a ton further back than my axle... I can roll mine around the dirt driveway with some help, but I can't lift the tongue alone.
    If my boat was that high, I'd have to park the truck in the lake to get it off the bunks. Most of the ramps near me are pretty gently sloped.
    HAHAAHAH, yeah I totally have to almost dunk my truck to get her off the trailer. Thanks for the pick. Do you have one of the front bow stop?
    1987 Supra Sunsport
    351 PCM
  3. #13
    Sep 2011
    Stevens Point, WI
    I just re-did my trailer to fit my boat. Not sure what the trailer was meant for, but it works for me. Here are some pics that may help you decide what you want to do. I would definitely ditch the rollers and build brackets for bunks. Mine are 2x6x10.
    Kevin
    1993 Supra Sunsport
  4. #14
    Sep 2011
    Stevens Point, WI
    Some more pics...
    Kevin
    1993 Supra Sunsport
  5. #15
    Apr 2002
    Austin
    kvand ...do you have a thread about your boat? grey isn't the most colorful shade but your boat looks tight. grey cover, trailer and grey platform...is this your handy work?
    tower looks great too? is it mc?
    is that perfect pass on your transom? (3rd wire)
    very nice...sorry for threadjack.
    back to topic...i'm with wiatowski. get a bunk trailer and sell your roller.
  6. #16
    Mar 2012
    Chain of lakes, IL
    Quote Originally Posted by kvand347 View Post
    Some more pics...
    Wow, thanks for the pics. The trailer looks sharp. Where did you get the bunk support hardware? Are you running this trailer without brakes?
    1987 Supra Sunsport
    351 PCM
  7. #17
    Jul 2011
    fort worth , tx
    Smp trailer .. It holds my sunsport great
    351 WINSOR SMALL BLOCK
    71C VELVET DRIVE
    13X13L 3 BLADE
    BRAND X 800 W 8 CHANNEL AMP
    8 INFINITY 255 RMS 6.5 LOUD SPEAKERS
    2 INFINITY 10" 2 OHM STABLE SUBS
    CUSTOM PAINT
  8. #18
    Sep 2011
    Stevens Point, WI
    I started a thread but I haven't kept it up. Search "'93 Supra Sunsport" and you should find me.
    The cover is actually black, but with all the pollen on it it looks grey. The boat and platform were the handi-work of the previous owner. I'm going to have to re-do the platform at some point because it is cracking. I painted the trailer to try to go with the boat. It ended up darker than the boat, but I like how it turned out.
    Tower is a fabbed up mastercraft. Works well for the lines of the boat. Again, previous owner.
    No perfect pass yet. That is the first on the list. The wire you see is the puck transducer for the depth finder.
    Thanks for the compliments! Wish I could take more credit!
    Kevin
    1993 Supra Sunsport
  9. #19
    Sep 2011
    Stevens Point, WI
    Quote Originally Posted by mabbore View Post
    You betcha! I thought they might help. I think you can fab up your trailer and make it work. Just takes some time, creativity, and some welding skills.
    Trailer is run without brakes, but they are on the list of things to get. I don't like not having them especially with kids in tow. I take it really easy and give myself lots of space. I do have drilled and slotted rotors which seem to help.
    The rear support came with the trailer. I just replicated that to make the front ones. You can see from the pictures how I did it. Shouldn't be too hard for you to fab up.
    Let me know if you have any questions or want any close ups. I'd be happy to help!
    Kevin
    1993 Supra Sunsport
  10. #20
    Sep 2011
    Stevens Point, WI
    Quote Originally Posted by lively View Post
    I'm super jealous!! Wanna trade??
    Kevin
    1993 Supra Sunsport
