Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Jul 2011
    fort worth , tx
    Quote Originally Posted by kvand347 View Post
    I'm super jealous!! Wanna trade??
    i got lucky .. with this one it had all that front stuff welded on before i just extended the supports , but if you look at my thread in the earlier pics and see what it is now .. man lol ..... its just rustoleom black gloss x10 can , and i sanded it down with my da sander .. new pine bunks with fresh carpet ... yours looks great man ! did a hell of a job ! and i like how your bunk brackets are long , sure you have 4 lags at least ?
    351 WINSOR SMALL BLOCK
    71C VELVET DRIVE
    13X13L 3 BLADE
    BRAND X 800 W 8 CHANNEL AMP
    8 INFINITY 255 RMS 6.5 LOUD SPEAKERS
    2 INFINITY 10" 2 OHM STABLE SUBS
    CUSTOM PAINT
  2. #22
    Aug 2010
    Ma/Nh
    I dunno if this is still helpful at all, but I was up at the lake over the weekend so I took some pictures of the bow stop
    Also, I really hope that's a reflection on the hull, 'cause I don't remember having a massive scratch there
    __________________
    87 Comp
  3. #23
    Sep 2008
    Parkersburg, WV
    [QUOTE=matt k;73613]a sunsport is just a closed bow comp, right?
    QUOTE]
    No - A Comp is closed bow, open bow version of a Comp is a Conbrio I think. The Sunsport is a deeper boat with higher freeboard and an open bow. The closed bow version of the Sunsport is a Marauder.
    www.waketheworldwv.com
  4. #24
    Sep 2008
    Parkersburg, WV
    Here's a side shot of my Sunsport. The engine is slightly forward of the front axle. This set-up rides really nice behind a half-ton pickup, truck sits level and rides great.
  5. #25
    Aug 2010
    Ma/Nh
    oh, yeah, that's a much deeper boat than mine, thanks for the correction
    __________________
    87 Comp
  6. #26
    I agree with lively. If u have a welder get some steel and modify that trailer. I bought a trailer for 500 and cut the back out and welded in a guard. It shouldnt take more than a few hours, including paint. Save ur $ for more upgrades on the boat!
  7. #27
    Mar 2012
    Chain of lakes, IL
    Thanks for all the pics guys, here is a pic of what I am wokring with. I know it is super sketchy. I plan on moving up the axels, then also moving up the rear cross support, building some bunks, alignment polls and a better bow stop.trailer.jpg
    1987 Supra Sunsport
    351 PCM
  8. #28
    Mar 2012
    Chain of lakes, IL
    Thanks for everyone’s help. I was able to do a temporary fix. I moved the axles up 15 inches to correspond with Michael's measurements. I also widened the rear rollers to give more room for the prop. It is soooooooo much better now. The lounge weight is just right around 300-400. Could not be happier for the moment. Next step is the brakes. They have not worked since I got the boat in February. I opened the master cylinder reservoir, and it was toast. Full almost to the top with chunks of rust. I would really rather rebuild it but I think I will just pick up a new actuator. Then on to converting to bunks. Baby steps, lol..
    1987 Supra Sunsport
    351 PCM
  9. #29
    Sep 2011
    Stevens Point, WI
    Quote Originally Posted by mabbore View Post
    Sounds like you got it to where you can at least use it without too much worry!
    Post up some more pics when you get some time so we can see your work.
    Kevin
    1993 Supra Sunsport
    5.8 351 HO PCM @ 285hp / PCM (40 A) 1.23:1
    Acme 422 Propeller 4 Blade 12.5 X 15.5 RH 1" Bore .105 cup
    Ballast: (2) 540 lb and (2) 350 lb Straight Line Launch Pad
    Wakeboard: CWB Absolute w/ Faction bindings / Surfboards: Hyperlite Coex & Broadcast
    "Don't measure yourself by what you have accomplished, but by what you should have accomplished with your ability." ~John Wooden
