Results 1 to 10 of 10
Thread: Getting close
    Feb 2012
    Ohio
    Default Getting close
    Getting closer to a test run. Just wanted to see how the seats were going to look in the boat. pirata.jpg
    Oct 2011
    Jonesboro IN
    Looks good
    I would love to have been out today if we had any water
    May 2009
    Looking nice, let's see more!
    2005 Supra Launch 22ssv - yellow/black
    Feb 2012
    Ohio
    Well I had to stop and bale hay. Hopefully we will finish up today. Got about 2000 bales to go. And that's just until the forcasted rain for tuesday passes by. Would like to take it to the lake tomorrow for a test run. I don't even know if the transmission works. It might not even float. lol
    I rented a dock at the marina so I could leave it there occasionally overnight. Thought that might be the easiest way to fix the trailer too. If I wasn't baling today I would hustle to get it ready and go out today.
    Feb 2012
    Ohio
    Did some more carpet work and fitted in more seats. backseat.jpgbackseat1.jpgbackseat2.jpgbackseat3.jpgbackseat4.jpg
    I through one in of my new baler. Would have rather spent the money on a boat. But needed it badly.
    Feb 2012
    Ohio
    The new baler
    Aug 2009
    NW Houston
    The vinyl looks great. I'm supposed to pick mine up Saturday - hope it looks as nice as yours.
    Apr 2002
    Austin
    Quote Originally Posted by gogger View Post
    what's that crazy thing in the back with the whirly bird things? i drive by some of those all the time and have no idea what they do.
    Sep 2011
    Stevens Point, WI
    Quote Originally Posted by Salty87 View Post
    That there is called a hay rake...mmmhmmm...
    Kevin
    1993 Supra Sunsport
    5.8 351 HO PCM @ 285hp / PCM (40 A) 1.23:1
    Acme 422 Propeller 4 Blade 12.5 X 15.5 RH 1" Bore .105 cup
    Ballast: (2) 540 lb and (2) 350 lb Straight Line Launch Pad
    Wakeboard: CWB Absolute w/ Faction bindings / Surfboards: Hyperlite Coex & Broadcast
    "Don't measure yourself by what you have accomplished, but by what you should have accomplished with your ability." ~John Wooden
    Feb 2012
    Ohio
    KV is correct it is a V wheel hay rake. Used to put mowed hay into windrows for drying and baling.
