2005 supra 22ssv stalling out
I just got a supra 22 ssv 2005, I took it out and it ran great for 2 hours at all speeds, then all of the sudden it turned off, it acs like it is out of gas, it will start right up, but not run mor than 30 seconds usually, I replaced fuel filter, and added seafoam and 10 gallons of new gas, I need help anyone know how to fix this problem?
Air, fuel, spark. Sounds like you have a problem with fuel if it starts every time. Can you check the fuel pressure? Possibly an issue with the pump?
1987 Supra Saltare
true
I took it to my friends supra dealership, I will ask them to check fuel pressure, they think, fuel pump, or vapar lock, or clogged gas tank anti siphen ball?????? I have no idea
