Results 1 to 5 of 5
    May 2012
    Blissfield, MI
    Default Fly High X Pole and Supra Comp
    Good evening fellow boaters. I just purchased a used Fly High X pole aluminum extended pylon for my 1988 Comp and it seems to fit loose over the factory pole. Is this normal or any suggestions to fix would be sweet. Thanks in advance.
    Jul 2011
    It's normal
    Apr 2002
    Austin
    tighten the bow strap and it shouldn't move.
    May 2012
    Blissfield, MI
    Thank you folks. I also talked to Mike at Fat Sac and received same advice.
    Sweaver
    Aug 2010
    Ma/Nh
    for what it's worth, mine has a plastic mesh tube (looks kind of like this: ) wrapped around the factory pylon to keep the fly high pole from banging around so much when it's not fully assembled and tensioned. It sort of works.
    __________________
    87 Comp
