Results 1 to 4 of 4
Thread: Timing
    Apr 2005
    Default Timing
    Just curious, at what rpm do you guys set your timing? I have an '89 454 L-10. Thanks
    Aug 2009
    NW Houston
    I set the timing at 2000 rpm on my 89 PCM 454. I'm running a Pertronix electronic distributor with mechanical advance, so wanted to get past the advance curve.
    Apr 2005
    sybrmike, at what degree BTDC do you set it at?
    Aug 2009
    NW Houston
    Honestly, I don't remember where I ended up. I think I started at 18 deg btdc @ 2k rpm, but backed off a bit to improve the idle. Like I mentioned, I'm running a Pertronix electronic distributor, rebuilt carb, air gap manifold, slightly worked heads, etc. so "your mileage may vary"...
    Here's a link I found for general reference: http://www.m2omarine.com/resources/PCMSvcQuickRef.pdf
