Results 1 to 2 of 2
    Default problems,need help!
    I have a few problems,does anybody have a problem or know a solution for the gas vent on a 95 supra comp,the hose that runs off the top of the tank is pinched off by the boat.My other problem,gas is leaking into my oil,we jsut got this boat it only has 200 hunderd hours on it and it looks like it.Well if anybody can answer ony of thses problems i would appreciate your help.
    ________
    CRF230M
    Sep 2002
    Maryland
    Default Carb or EFI?
    If you have a Holley Carb, check the float levels. A friend of mine had the same problem on a '98 Comp. Gas was running down the carb, past the rings to the oil.
