I need to reattach the top of the N on my side launch decals. Has anyone had any succes doing this? Krazy Glue seems to bond to everything but will it work in this case? Any other suggestions?
Thanks,
John
Thanks,
John
I would be careful not to use anything that would chemically "attack" the gelcoat. You definately want the decal to be able to take the decal off at will without having damaged the gelcoat. If you cannot find an adhesive that will be "friendly", I would look into replacing the decal.
www.waketheworldwv.com
Try some adhesive silicone, I have used it on the boat for minor jobs for years, dosen't seem to hurt the gel at all.
Ditto on silicone adhesive. Bubblicious may work also. But personally I would use silicone.
