I just recently bought a 1988 Supra Mariah with a PCM 351 in it. I got it for a steal. However when I go to start it I get nothing no clicking or anything. Also none of the gauges are working and none of the devices are working (ie blower, blidge, light etc) I have tested the battery and it is good and is fully charged. I have jumped the connection at the starter relay and it turns over but does not start. I have even attempted to to bypass the nuetral safety switch with no luck. I even pulled the panel out and jumped the lines for the key switch with no response. I am not sure what else to try. The battery cables to the starter relay and ground to the block from the battery are new and in good condition. I am not sure what else to try except for replacing parts but I am not sure what parts maybe bad at this point. I would really appreciate any advice you can give me. Thanks
