What trailer maintenace does everyone perform on an annual basis?
White/Charcoal, 2011 VLX
2008 Supra 22SSV
Clean and grease your wheel bearings at the start of each season.
Inspect and repair as necisary:
Brake system
lights
I'm up North where the winter is pretty harsh so I like to put my trailer up on jackstand's and grease and turn the wheels so I don't get rust spots on the bearing races, everything else would be a ditto to what Rick said, wiring lights, lube the the leg at the front of the trailer, and a little dielectric grease in the wiring harness connector......
90 Conbrio
Ditto on the Ditto, but I believe all the newer trailers have oil bath bearings. I changed the oil in my 05 trailer hubs last fall given I personally had put several hundred miles on them and who knows what the previous owner did. Turns out the oil looked just as fresh as the new oil. I still plan on checking the oil level each spring, mid summer, and fall, but will probably only change every 2 to 3 years. Anyone have any different recommendation?
My 08 trailer says they are "supposed" to last 5 years.
The only other thing I seem to have to deal with is staples for the
carpet on the bunks. Mine is only a year old, but I have had to
add staples 2 times now (stainless steel staples) - as I have noticed
the carpet sagging.
I have oil bath bearings as well, other than a reverse light that filled with water a couple months ago, the trailer has been great. Called boatmate and they sent me a new light free or charge.
Sounds like with the oil bath bearing setup not a lot of to do for maintenace.
2008 Supra 22SSV
