The steering wheel on my 03 launch SSV is off by about a 1/4. Has anyone removed the steering wheel to adjust? I am a novice at best. thanks for your advice.
John at Lake Lanier, Atlanta
John,
Just remove the allen bolts that are holding the steering wheel onto the adaptor. Then move it to the next bolt then re-tighten. To get your steering perfect you need to take it off on the lake when you find the true straight line. It never seems to work out right when you do it out of the water.
You can also pop off the center cap, remove the bolt and take it off the spline. I believe you will need a puller to do it this way.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
Yep What Fman said. I took mine off in the garage then put it in the water and it was off at least 1/8 to 1/4. The water test is best. My steering wheel pulled right off no problem. Fairly easy to adjust.
'06 21V Launch N2Orbit "HydroFoil Edition"
N2Orbit Hardcore Hydrofoils Team Rider
http://n2orbit.com/
http://velocitywatersports.net/
http://foiltechhydrofoils.com/default.aspx
On my 89 Sunsport you can adjust the steering cable at the steering swivel near the rudder under the center rear seat access panel. To get the wheel perfect you would need to make adjustments on the water and keep checking after every adjustment.
I have the same issue on my 08' Sunsport. Dealer seemed to think that you couldn't just remove the wheel and adjust the splines, but I haven't looked at this for myself yet. Sounds like these guys have experienced it, so hopefully its as easy as they make it sound!!
http://n2orbit.com/
KO1, sounds like my issue. It was off from the factory too. If it can be moved on the splines, should be super easy, only problem is I won't be able to get it tested out until the spring. With it being an 08' it shouldn't be a cable issue. Thanks for the input.
