Results 1 to 6 of 6
    Oct 2009
    Default 2003 supra ssv 22
    looking at my first supra its an 03 22 ssv with 1100lb factory ballast. my question is this, im a beginner can do 180 wake to wake some trick on the flats and so one. But this was all done behind my buddies 04 wakesetter. will this setup satisfy me for a while and will it throw a great wake or will I be disappointed. Im drving pretty far for the good deal but just wanted some input before i go on friday any help would be awesome.
    Sep 2009
    Western PA
    I can tell you coming from an I/O to 22 SSV was amazing without being able to do any tricks on a wakeboard yet. Looking toward spring. I think it would throw a comparable wake, but I can't tell you for sure. You should be satisified with it because it is your boat and not your buddies...Good luck.
    Oct 2009
    true it will be great to have my own but I was just curious how the wake going to be with just the 1100lb of ballast
    Default supra
    I have a 2003 ssv and te wake was not to bad with the stock ballast. I switched out the back sacs for the 750lb fly high sacs and it made a big difference.
    Does this have the playpen bow? If so you can probably change out the front bag for the Fly High GG 1100 lb bag.
    Oct 2009
    hey 98 outback thanks for the response. so you put 750s in rear. Did you leave your stock 600lb in the mid ship or upgrade?
