Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Aug 2009
    Atlanta, GA
    Talking Ford 351 Motor Rebuild
    Hi Everyone
    I have started to reasemble my new engine after I found the block had cracked and replaced with a remanufactured block, I have sandblasted and repainted the whole engine but was trying to find the torque settings for all the bolts on the motor including the rocker arms etc.
    Does anybody know where I may be able to find this info?
    1989 Ford 351 Winsor Motor
    Thanks for all the advice so far, Cant wait to get the boat going and try her out.
    1989 Supra Sunsport
    Sep 2008
    Parkersburg, WV
    I have them in my PCM manual. Send me a PM with your email address and I will send you the .pdf file - I have the entire service manual scanned so I can send that to you or just the pages that you need. -Clint
    www.waketheworldwv.com
    Aug 2009
    London, Ontario, Canada
    Fox, Do you have any pics?
    2009 21v Worlds 340 Cat
    Doug
    Jul 2007
    Flowery Branch Georgia
    Fox
    I checked in the PCM owners manual and a web search and didnt find torque specs.
    If you go to your local library they will have the info in the reference section.
    Also the PCM owners manuals are available on the Planet Nautique forum.
    Sep 2008
    Parkersburg, WV
    Fox
    It's not in the PCM owners manual - it's in the PCM FOrd Engines Repair and Diagnostic Procedures Manual. I have it and can send it via email.
    Sep 2008
    Parkersburg, WV
    Anthony - check your email. You should have the information you need, but let me know if there is something else.
    Feb 2009
    brothers performance has a whole list on the website. yes its for mustangs but all the specs should be the same
    Aug 2009
    Atlanta, GA
    Quote Originally Posted by csuggs View Post
    Thanks Clint
    Started putting the bits on last night.
    The reason I'm rebuilding the motor is I bought the boat with the motor been possibly in a freeze, Come to find it cracked the block and mixed water into the oil, The motor had 820 hrs on it and was running fine before the freeze.
    I only paid $2000 for the boat and trailer and have about $800 in the motor so far so im doing good as the boat is in good shape with only one owner.
    1989 Supra Sunsport
    Feb 2009
    Minneapolis, MN
    Good job, keep up the hard work
    Aug 2004
    Pittsburgh, Boat lives in Chautauqua NY
    Default long or short block?
    Question - I have seen short and long block 351W motors I guess I never knew there where two different versions of the small block 351W. I am assuming our boats use the short block. Is that correct? Can anyone shed some light on the difference between a short and long block?
    I have seen complete motors on Craigslist for $200. My motor seems to be fine but I have always wanted to learn how to rebuild a motor. Maybe stroke it while I am at it and drop it in the boat someday or have a spare in case mine goes bad.
    1984 Supra Rider
