Results 1 to 7 of 7
    Apr 2010
    Houston , Texas
    Default ANother Holley Carb. question....
    first off , brand new carb ( 750 cfm )....
    boat has ran great in the driveway , while ive been getting it ready for the water . First day out was Sat , ran great and ran a tank off gas thru her . second day was last night , ran great in the evening to watch fireworks ( 1/4 of tank ) ......my GF and son took her out today took her out today , she ran fine for about 20 minutes ( avg about 22-2600 rpm ) the sputtered and then stopped,,,,sat for 5 minutes the she cranked up and ran fine for about about 5 minutes , then same problem...I went down to the dock , jumped in and took it for a spin....ran like a top for about 10 minutes @ about 3000 rpms....when i slowed her down , she sputtered and stalled and the process started over with me.......
    any clues on what could happen to a brand new carb
    Brack
    1984 Supra Rider
    454 / 1:1 trans
    213 Hours !!
    " work in progress "
    Jul 2008
    Whidbey Island Washington
    This sounds simular to an experience I had with a friends boat long ago. The fuel tank vent was plugged, and it would only run until the fuel tank developed a vacuum, then it would quit. It could run longer at low power, but only a few minutes at high power. The quick test is to see how it drives with the fuel tank filler cap off.
    The fix, at least what I did to my friends boat, was to blow the vent obstruction back into the tank. Simple, and no cost. This wss after my friend spent thousands on shop bills where the mechanics just sat back and thew parts at it.
    Rick Ludtke
    1987 Supra TS6M Comp
    Photo Album http://www.supraboats.com/bbs/album.php?albumid=4
    Apr 2010
    Houston , Texas
    Thanks for the comment about the gas vent......i pulled my tank last month and installed a new line....vents OK
    ........OK , think i found it , i decided to check my fuel filter and unscrewed the canister and relalized i didnt put a filter back in when i cleaned my tank . That wasnt my problem , The canister was half full of water ......cleaned it out and replaced the filter THEN i hooked a pump up to the tank and drew a gallon of gas thru the pick-up tube to check for water....all seemed ok , no water ....Question is though , how did the water get in there , she ran great for the two previous trips ???
    hopefully test it out sometime this week
    Brack
    1984 Supra Rider
    454 / 1:1 trans
    213 Hours !!
    Apr 2010
    Houston , Texas
    Default what was in the fuel filter cannister
    nice looking huh ???
    Brack
    1984 Supra Rider
    454 / 1:1 trans
    213 Hours !!
    Jul 2008
    WOW, thats ugly!
    Rick Ludtke
    Jul 2007
    Flowery Branch Georgia
    Looks like swamp water where did you buy the gas?
    Apr 2010
    Houston , Texas
    ..at the nice lil corner store.......nice huh.....anybody have some advice for a fuel / water separator.....with a clear bowl....all the ones with a clear bowl has been for diesel..
    Brack
    1984 Supra Rider
    454 / 1:1 trans
    213 Hours !!
