Results 1 to 5 of 5
    Nov 2009
    Austin, Texas
    Default Carb Power Valve
    I would like to hear from some of you that have a Ford 351 Winsor. What size power valve do you use in your carb's. I have a 65 and a 75 can't figure out which one to use
    May 2009
    syracuse Indiana
    both the 6.5 and the 7.5 are car style power valves. Way too lean for marine use. The most optimom is a 2.5 or 3.5. I regulary install the 2.5 for instant accelleration. Order from Holley or I believe you can also order individually from Summit. Al
    Nov 2009
    Austin, Texas
    I ordered the rebuilt kit that Holley told me to. It was a marine 4160 kit and it had the 6.5 and 7.5 in it, are you telling me they gave me the wrong size. I gave Holley my list number and told me the 703-28 was the kit for that carb
    May 2009
    syracuse Indiana
    They sent you a basic rebuild kit. Each marinizer has their own specific jetting. ie Inmar, pcm, crusader. Order a 2.5 or a 3.5 and experiance the optimom accerleration. Al
    Nov 2009
    Austin, Texas
    Thanks beast I'll give it a try
