having a trim problem
have 2007 22v launch. trim not responding and i am having a problem locating a fuse for it (i checked a small fuse panel underdash and all good)
I was having problems with my wake plate adjusting the trim on it not working. Ended up being the connector for the fuse was not giving a tight connection. Took some needle nose pliers and squeezed the connectors tighter and have not had an issue since. One thing you may want to try is to open your engine hatch and turn the ignition on and listen to see if you hear the hydraulic pump clicking, you may need somebody to be at the engine hatch listening. It is either the fuse or a the trim switch. Just basing this off of my issue.
