Results 1 to 3 of 3
    Aug 2008
    Default replacing supertraps with rubber flappers
    can i just unbolt supertaps off the back of my 87 comp and bolt on rubber flappers without any mods.
    Sep 2004
    Hudson, WI
    I believe that you can. I recently installed Fresh Air Exhaust and the part that mounts to the boat is basically flapper flanges without the flappers. You may have to cut the mounting bolt off that the supratrapps screw on to. I'd also use a generous amount of black RTV to seal the hull to the flapper flanges.
    1987 Supra Saltare
    Feb 2009
    Minneapolis, MN
    There is a threaded bolt that sticks out the rear about 4" or so. It would need to be cut off.
