Results 1 to 6 of 6
    Sep 2009
    Default Impeller - does it matter which way it goes into housing?
    Hello everyone. I'm a new DIY ... and first attempt at replacing impeller on 03 Launch SSV. I want to make sure that it doesn't matter which way the impeller is inserted into the housing, Also noticed that the old impeller has noticibly curved tines. Should the tines curve clockwise or counter clockwise.
    Thanks for your help!!!
    Nov 2009
    Skowhegan, Maine
    yep only goes in one way
    Don't get Emotional, It's just a boat.
    TIA (Try it Again)-1991 Supra Sunsport
    Aug 2009
    London, Ontario, Canada
    does not matter which way the impeller goes in, you want to lube it KY works well and then rotate it in a clockwise rotation to bend the splines back to the left if your looking straight at the impeller, then once its engaged the splined shaft push it straight back in, reassemble gasket and cover....so the splines will curve back in a counterclockwise direction as the impeller spins in a clockwise rotation
    2009 21v Worlds 340 Cat
    Doug
    Sep 2009
    Thank you both for your help.
    Jul 2007
    Flowery Branch Georgia
    docdrs is correct . For the off season leave is out and reinstall it in the spring. No sense having the impeller folded over for 4-6 months.
    Mar 2009
    Roseville, CA
    Quote Originally Posted by Jidol View Post
    Check out this how-to video, its on an Indmar.
    http://www.inboardonline.com/how-to/
    You might have to click on the "How To" link.
    White/Charcoal, 2011 VLX
    2008 Supra 22SSV
