Supra Boards
  #1
Old 01-27-2010, 05:49 PM
ssmith's Avatar
ssmith ssmith is offline
Senior Member
Location: Cookeville, TN (between Center Hill and Dale Hollow)
Default Sac stacking???
I know "iwakeboard" mentioned it and I've wondered this....is anyone else routinely stacking a ballast bag on top of another? I could fit 2 into my v-drive compartment but I worried it would either push water out of the bottom sac or somehow damage the ballast system.
__________________
Scottie
2005 Supra Launch 21V
http://i175.photobucket.com/albums/w...TMxNS5qcGc.jpg
  #2
Old 01-27-2010, 06:49 PM
87SunSportMikeyD's Avatar
87SunSportMikeyD 87SunSportMikeyD is offline
Senior Member
I have stacked sacs on the floor of my DD many times. Please excuse my universal guesture for 'whos sacs? deez sacs'
  #3
Old 01-27-2010, 06:50 PM
iwakeboard's Avatar
iwakeboard iwakeboard is offline
Senior Member
Scottie,
I just noticed you have an '05 21v, my buddy had the exact same boat and stacked his bags for the 2 years he had it. He never had a problem with it, but someone who is more familiar with the system may be able to speak more in detail about how it may or may not affect the system.
__________________
2005 Supra Launch 24SSV
  #4
Old 02-02-2010, 02:24 PM
jasonwm jasonwm is online now
Member
You would need to put a VERY large sac on top of the factory one in order to develop enough pressure to force water out of the bottom of the bag (where the drain pump is attached) and through the drain fitting in the side of the boat. So there's really no risk to doing that, it's mainly just the convenience issue of having one larger bag connected to your factory system for automated filling and draining vs. having to manually fill a bag after your factory system is done filling.
__________________
WakeMAKERS.com | WakePROPS.com
  #5
Old 02-02-2010, 10:52 PM
ssmith's Avatar
Senior Member
Iwakeboard, thanks for the info & Jason, thanks for the confirmation. Jason, I need a few fittings from you. I'm changing my stock 250 lb bags over to a Tsunami configuration. So I'm removing the QD's and replacing with whatever you tell me. I'll be in touch.
__________________
Scottie
  #6
Old 02-03-2010, 11:57 AM
Member
Sounds good, just let me know what you need, or give me a ring and we can talk through it.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 2007 Skier's Choice, Inc.
All Rights Reserved
